Superlift Sway Bar Links
How Much Fluid 4 Mag-Hytec
Right rear Trailer Light Problems
I have the Tuff Country 6" front box kit on my truck, but dislike the way they did the sway bar so I purchased the Superlift links. Problem is on the tuff country setup the bottom mount is flat and the Superlift links are made for a vertical mount. Am I missing something?
The Tuff Country set up is way better IMO. I bent two sets of the longer links (SuperLift) with out even trying. Just flexing your truck up going threw a big drive way approach would bend them. The drop bracket on the frame and the big short links have held up with no problems. My 2 cents
For the tuff lift the stock brackets are cut off the axle and new ones are bolted on. The superlift end links bolt to the stock brackets. There is not a lot you can do now, unless you can get some stock brackets and have them welded on. Good luck.
