Ran across this info from Superlift regarding their new lifts for 2003 HD Ram --- I apologize if it is old news, but it was new to me, so figured it may be useful for some. Here's a quote from their news release:
2003 and Newer ¾ and 1-ton 2", 4", and 6" Systems
The newest heavy-duty Ram trucks are a refined version of the previous generation; they share the same basic coil-link suspension design. All three lift heights feature new Superide coil springs. Different rated coils are offered for the Hemi and the heavier diesel and V-10 gas engines. The coils are matched sets with an improved rate curve and ride quality that is second to none. The only other components used in the 2" front leveling kit are new Urethane compression travel stops. New Superide shocks are recommended with the 2" system, but not required.
The 4" system, in addition to new engine specific coils, includes a dropped pitman arm for steering correction, specially designed compression travel stops for the front and rear axles, a new track bar relocation bracket, and all new axle-to-frame link arms to restore factory alignment specifications. Optional Rockrunner links are available for those who demand optimal articulation and off-road performance. Lift blocks raise the rear two inches to negate most of the factory nose-down stance. The factory rear springs are well designed units so axle wrap-up is generally not a problem.
The 6" system is basically a taller version of the 4" lift. As with the 4" lift, the 6" is available with standard one-piece front axle-to-frame links, or with Rockrunner swivel links.
Options for the big Dodges (all heights) include: front and rear multi-shock systems, a brushed stainless steel skid plate featuring the new flame logo, and a dual steering stabilizer system that is available with standard bracketry or with our new 3-D flame design. Bulletproof brand, extended-length Kevlar-reinforced braided stainless steel brake hoses improve both your vehicle's brake system performance and its looks.
