I am about to install some supplemental LED backup/work lights. I need to find the 12V backup light wire and/or connector under the dash if possible.
I have a three position switch that I will mount on the dash. I want auto reverse on, off, and work lights on (with pilot indicator). This means I need a couple of relays to get the arrangement I want. One of the relays low voltage signal will be via a feed from the back up lights when they are on in reverse. So I need to figure out where and how to tap into that. Getting it under the dash or somewhere up front would be good if that is possible.
I cannot get the wiring diagrams for the 2016 truck via Tech Authority yet. I'm guessing they are the same as the ’15 but not certain. Anyone have a wiring diagram of the reverse lights for a ’15 that they’d be willing to share?
