I tee's my injector return line in the return to tank years ago but didn't gain or see any advantage except it's easier when you change injectors.
On the A1000 I set mine up like bgilbert did with a -12 supply from the bottom of the tank as I want it to live longer, plus it allows for more/bigger pump later on if needed.
Garrett, if you can't run a sump then a stan pipe will have to do, just try and make it really big.
Signal, that pickup is a slick piece, what size do they have fitting for -8, -10 or -12?
While were on the subject! As you know I still run the stock system on my truck and run the A1000 as a stand along backup when I'm on it. On my supply I run a -10 all the way up to the pump then take it down to a -6 at the banjo inlet. I have -6, -8 and -10 fittings ordered for the front inlet above the rack plug and I will put the biggest line on in there that willl fit. It will still be a duel feed using a -10 Y block.
Jim
