hasselbach said:The exhaust band clamp is 100 inch pounds, not 100 ft lbs as noted in #10 in Alan Regans post.
GWBourne said:yes, the torque specs will help big time. i think i will just remove the manifold though... wire the turbo up to the firewall or do something else to support it that wont get in the way. this makes the job a lot easier as i am doing it in a parking lot at the barracks. dont have the ability to be pouring oil into and out of oil lines and turbos.
i will be tearing it apart tonight and will let everyone know how it goes, then drilling and re-instal tomorow.
Why are you removing it? If it is just to drill and tap the stock manifold for a pyro, there is no need to remove it.
GWBourne said:like i said, i could be off on the size, but i know it is larger than 1/8 and not just by a little bit. if a bolt falls out ill replace it. a torque wrench is a great thing and works great for keeping things where they go. yes, the bolts strength has changed a bit and streached a bit from origonal instal and all the heat cycles, this i can deal with. they will still hold torque, and if checked a couple of heat cycles after re-instal then they will be fine. im not a new mech, nor am i dumb. i am over cautious and some times paranoid.
gaskets being 10 dollars each isnt a big deal. how much is a turbo? if placed correctly on the monifold there should be no problems with a 1/2 inch hole if it is that size.
GWBourne said:every tap i have used the drill bit required is one step or so smaller than the tap... . i dont see how it could be larger... . i will get the size tomorrow night and post it up for sure.
Grant
