Engine/Transmission (1994 - 1998) Surging??
Engine/Transmission (1998.5 - 2002) Silicon and Blackstone and K&N
Engine/Transmission (1998.5 - 2002) NV-4500 leaking
While pulling my 5er the engine seemed to "surge" slightly three times. The tach needle briefly went up then back down. I was only going about 45-50mph on a flat road.
This happened a couple of times months ago on the highway when empty(65mph).
What is this indicative of? (forgive the ending preposition).
Check your rubber fuel hoses, Filter, fuel strainer for a start. Could be more. I'll let the experts on here answer more.
It sounds like your throttle position sensor (TPS) is dirty or has a poor connection. Do a search for TPS for much info.
I agree with illflem... . my TPS acts up every now and then which caused the TCC to unlock and the RPM's go up and then down as a result.
HTH,
Matt
My first guess would be the fuel filter. It's a cheap and easy way to start your trouble shooting. Another possibility is the fuel screen being clogged. I think the screen is part of the fuel pump (I've never cleaned mine!)
tps noise was my problem. i pulled the wires out of the harness back about 2 feet and the problem went away immediately... .
