I was playing around on the way home from work today and was totally shocked by my torque converter. I had a DTT 91% for over a year and switched it out for an 89% in December.
You'll have to understand that I don't have a locker yet, so tire spin is quite easy in my truck. I pulled out onto the highway and stepped on it with a little propane flowing and OD off. The right rear tire spins through second and kept spinning completely through 3rd as well. My tach was stationary at 3100 rpm and my speedometer read 78 mph. It was frozen like this for several seconds as the vehicle speed catches up to the spinning tire.
What shocked me was a few seconds later I locked up my TC clutch at 78 mph and the tach read 3000 rpm.
Could this be right? Full power and only 100 rpm difference between lockup and fluid coupling? I know TC's get 'tighter' as rpm climb, but under a heavy load with several hundred ft-lbs of torque I thought there would be a bigger difference.
Just thought I would share that tidbit.
-Chris
-Chris
