Swaping seat bottoms
A big thanks to the TDR & it's members for May Madness
Rear Differential Temperature seems a bit hot
I read here where somebody swaped the seat bottoms from ds/ps.
I was cleaning the inside of the truck and figured "why not, its got 80K and the PS seat feels better then the DS"
So I removed the seat bottoms, only 4 bolts so it was easy to remove.
There is a difference between the DS and PS seats. In my 98, there is cloth on the outside and vinyl on the inside, but what the heck, I will switch them anyway.
So I have them switched and notice, the seat no longer comes all the way out to the out side plastic trim, there is about 3/4" between the trim and the seat.
I switch them back and yes, the outbound side of the seat sticks out further then the inside. This shape is sewn into the seat cover.
This is a 98. 5 SLT no leather.
TowPro,
I did the same thing thinking I could balance out the wear since the pass. side rarely gets used. Found out the same thing you did. #ad
Oh well, maybe I could try driving from the pass. side for a while! #ad
Dennis D. Tway
"RATTLIN" *1999 2500 SPORT QUAD CAB* "RAM"
IntenseBlue/SB/Cummins/4x2/auto/3. 54AS/4whlABS/Camper&TowPkg/
Keyless/Leather/TravelConGrp/SecuritySys/6spkrCD*Cass/Strngwhlcntrls/
WestinTubeSteps/SportMastersSoftTonneau/15k RBW 5th-WheelHitch/26'Nomad 5er (looking for a bigger one) and a way to take my HARLEY too!
-- email address removed -- or -- email address removed --
I was going to swap mine also. Thanks for the heads up, will not do it now.
1998. 5;24v,3500,4x4,SLT,QC,5 spd,3. 54LS,4whl. ABS,all options,18k lb. Reese 5th whl. hitch,full length diam. plate running boards,eyebrows & hood dam,bed edges,bedhooks;gray Rhinohide liner,Pac Brake,britebox,"deepdish"mats,matching shell,Sandstone & camel leather,stainless fender eyebrows,exhaust turndown pipe;brush guard,SPA digital boost/egt(pre-turbo) gauge,pillar mount, darkened door windows, Lowered rear end 4".
See My Truck
1980,W200 Powerwagon,4 door crewcab,360 gas,747 auto,68k orig. miles,4 coats of Zeebart.
The Powerwagon
My Boat
I notice the three of you posting so far have 98. 5 or newer... . what about say a 95? #ad
anyone?... Jim
1995, 2500, 4x4, 3. 54, auto,130,000 miles, custom fuel plate, boost and EGT gauges, 215 HP injectors, RE-0880, custom 4" from down pipe.
