Ok I know this has been talked about a zillion times, but every post I see has different amounts of parts and such PS I have a 98 12v shortbed auto (obviously)
the transmission is going to be a blumenthal with the 1 3/8" input and a south bend clutch
instead of shortening/lengthening the driveshafts, I figured to save time I would just get teh driveshafts from the same vehicle in a salvage yard but of a truck that was a manual transmission
Im also going to get a flywheel off the board here
now going off this site
http://www.high-impact.net/transmission_and_gear/nv4500_dodge5.9diesel88-03_auto.htm
leaves
the shifter (again I can get this in a salvage yard)
Dodge master, slave, Hydr line & Fluid reservoir assy (not sure exactly what all of this entails) can this be had at a salvage yard as well or atleast cheaper new or something?
Bellhousing ( I read in a previous post the one from the auto transmission will bolt up?)
Engine Adapter / Flywheel Housing ( I honestly dont know what this is or where to find that in a salvage yard)
(release fork, pivot and spring) would these or some of these come with the new clutch?
starter (Ive heard the auto starter working as well)
transmission crossmember, should I just get one from a salvage yard as well?
Pedals, I guess this is salvage yard as well, do I need all three or just the clutch and what else with this?
Thanks and I apologize for taking up so much space, but I am trying to put this together best I can because I cannot find a stick shift 12v shortbed so I need to literally make one.
thanks
Carl
leaves
thanks
Carl
