Swapping out 5 lug hubs
Looking for info on enclosed car trailers
Truck Camper Wiring
My travel trailer has 15 inch wheels with 5 lugs. I want to know if I can change the hubs to 6 (or maybe 8) lug hubs, then put 16 in wheels/tires on it.
I need some advice.
Here's the facts:
Trailer: 2004 Komfort 23T (bumper pull)
Axles: 2 (GAWR 7000 lbs)
Wheel well clearance:
18" from Ctr of axle to top of wheel well (closest surface to axle center-point)
31. 5" from Ctr of front axle to Ctr of rear axle.
So my questions are:
1. Is it possible to change the hubs from 5 lug to 6? if so... Is it difficult?
2. will 16 inch wheels and good LT tires have too large a radius to fit in my wheel wells, and have enough clearance to be safe?
3. will the tire width (with new hubs/rims & 16" tires) be significantly wider (& possibly interfere with my fenders)?
4. Anyone have an alternate idea that might be easier/less expensive? (please don't say buy a new trailer. . )
Thanks in advance for the help.
Scott-
Give Dexter axle a call or etrailer.com. Your axles are probably either Dexter or Alko. If you have 12"X2" brakes, you should be able to change over to 6 or 8 lug. Get the specs on 16" tires you would want to use and check if the additional radius would be a problem. You may find a 16" with about the same dimensions as your 15", only higher load capacity. Width may not be too much of a problem unless your 15" are tight.
Thanks. How do I know if I have 12"x2" brakes?
Also, if 6 lug and 8 lug hubs are available, which is it better to go with? what's the rationale for choosing one over the other?
And I know this has been bandied about a lot in past posts... But what is the current wisdom regarding a good tire for this application?
Finally, does anyone know the OD and width of the 16" tires that they recommended?
One more question... what is the safe separation dimension between front/rear tires? Since the Ctr to Ctr dimension of my axles is 31. 5", that means if I mounted tires with an OD of 30. 5" I would only have 1" of clearance between the two. that seems kinda scary:eek:
IIRC, I found the brake size on etrailer.com. If your axles are 7,000GAWR, they are probably 12"X2". Look up brakes on etrailer.com, they were listed by size and axle weight rating. I have 6 lug rims on my 5er. With 8 lug, in a pinch, you may be able to use your truck spare. Backspacing could be a problem as most trailer wheels are 0 backspacing. I'm running 235/85/16 Michelin XPS ribs. They have limited sizing. Other tires that have a good following are, Bridgestone Duravis R250 (I believe), and BFG commercial. There are a couple of good threads on here regarding trailer tires. You can also try RV.net and IRV2. Tirerack.com is a good place to find dimensional specs on tires.
That does sound a bit tight. I don't know the minimum you would want to go. Maybe someone will chime in on that question. I've read what a minimum clearance would be, but I can't remember.
With 5 bolt wheels you probably have 3500# axles with 10x2. 25" brakes. I doubt you can upgrade the hubs and brakes to a larger size. The 5200# axle would be a 12x2" brake and 6 lug wheels.
Nick
The GAWR that the web site has is for two axles, 3500x2=7,000. You should have a GVW tag on your camper that will show the spec's. A true 7,000# axle is an 8 bolt pattern.
Nick
A 3500# axle will have 2 3/8" diam. axle tubes... ... . a 5200# or 6000# will have 3" tubes. If your gross axle weight says 7000#... . more than likely you have 3500# axles.
After crawling around last night looking at them, 2-3/8" seems about right. I thought GAWR was how much each axle could take. I guess I was wrong... :eek:
So, I am stuck with 15" wheels and no chance of getting LT tires on this thing? #@$%!
Ok, what is my best option for tires then? any suggestions? Seems I read something about a 15" Goodyear Workhorse that might have been an LT tire. would this fit/work for me? If I can't get a good LT tire, what is the best alternative?
Any other options? maybe new axles?? (I don't want to spend a ton on this)
I replaced my 3500# axels with 7000# put the springs over the axel and now 235 75R 16E tires. Raised the trailer up so the ground clearance is like a 5th wheel trailer. The trailer is a 05 R-Vision. The new tires and wheels ride better (And don't bend axles. ) The 7000# axels have 6 lugs. Had the change done at MorRyde in Elkhart Indiana 3 years ago was ready to dump the trailer, now I won't consider getting rid of it. The whole conversion with 5 new aluminum wheels cost less than $500' (with out new tires) The trailer came with 14" China specials. The 16" Michelins made a huge difference. Also use a Hensley hitch.
Nick
I did some research and to my surprise, you can get 6 on 5. 5 bolt pattern hub/drums for the 3500# axle. Both Alco and Dexter have them. The brakes will stay at 10x2. 25".
Nick
So I priced it all out for 4 of the following: Dexter 6 on hub/drums , brakes, 16" wheels, Duravis R250 LT225/75R16 tires, just shy of $1600 delivered.
The peace of mind I have the next time I hit the road without the 15" willpops under my trailer... . priceless!
Thanks to all.
When I went looking for an LT tire for my utility trailer my tire guy said an ST tire has more plies and a stiffer sidewall. I ended up with a Hercules ST205/75R15, load range D, 2,150# at 65PSI. Most 15" ST tires are load range C but there's a few Ds and Es out there.
I was looking at TireRack and found 14" LT tires! They are Yokohama Y356 highway rib, cost about $100, but wouldn't need new wheels.
