Sway bar brackets gouged?
Loud Clunk With Side Sway???
Changed fuel filter
I may be getting too picky on this but while doing my oil change I noticed nicks and gouges on the front sway bar brackets. It looks as if someone ran into a rock several times. The right one is worse then the left one. I'm wondering if these happen during shipping. Has anyone else noticed anything like this?
'01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
Mine doesn't have any marks,but does it look like your marks came from the chains used to tie your truck down to the delivery rig?
-Mike
Yeah, something like that. At least that's all I hope it is. The brackets are straight and they don't look like they've moved, they're just a little beat up.
You ever notice that Dodge is the only one of the big three who's 3/4 ton and larger trucks don't have tie down loops or hooks?Guess they figured that wraping chains around the axles is good enough,cheaper too. #ad
Yep, that's where it comes from. You're so right Bill, just like using fuel line not meant for Diesel after all these years on the return side. Cheaper to warranty it out and use garbage than get a real fix.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
