Hello all, I know oils have been discussed several times before, but has anyone used Swepco brands?
I'm interested in opinions if anyone has used Swepco. (hopefully no oil brand wars)
I've been using these oils in my 1997 ctd with good results.
Most noticeable was the Swepco 80w90 gear oil in my nv4500. I've got 40,000 kms on the oil since putting the oil in and so far has worked great.
In the spring, my cummins blew apart the stock clutch with it's AW chassis dyno'd 283 rwhp/942 rwtq, the transmission was removed and inspected. So far (it's a '99 nv4500 with upgraded nut) it's in excellent condition, the nut still tight, gears looking good, bearings within specs, synchros shifting nicely, etc. New clutch installed and transmission put back in. (this transmission came out of a 1999 dodge dually with 400,000 kms on it. )
My brother in law and I rebuilt this transmission ourselves 3 years ago when I did the auto to manual swap. All we've done was bearings, seals, synchros and one 3rd gear (it was chipped).
Now there's 80,000kms of daily driving, many dyno runs, several drag racing, heavy hauling, and now sled pulling since the rebuild.
What I really like about this oil is it's additive package, the ability to climb up and completely coat everything in a thick film of oil rather than just splash coating. All the bearings, gears are completely coated in this blue stuff. Also as far as I'm seeing, the oil has not been a problem to the synchros.
The oil doesn't run down quickly, doesn't foam much (foam is air bubbles going through the gears) and I think cushions the gears much better against the cummins high torque vibrations than the thin oil supplied by chrysler.
I'm hoping this article would be of interest for anyone who wants to try another brand of oil.
I'm hoping to be of help by letting others know that Swepco is another good product that's not well known except by those who use it as it's not advertised to help keep cost down. I found out about Swepco by word of mouth.
As time goes on, I'll be checking my truck to see how everything is doing as power level goes up and how well the oils are doing to work with the mechanical parts.
There will be a new clutch going in as I couldn't afford an SBC clutch at the time when the old blew up, so the same brand as the previous clutch went back in.
If there are any questions or whatever, I'd be happy to discuss.
