I am installing an electrically actuated exhaust cutout from Race Ready Performance (4”). Since my truck does not have the power adjustable pedals I have a very nice spot currently with a blanking plate for a potential switch install location. I would like to use the dodge power adjust pedal switch but not sure if I will be able to.
Speaking with Steve at RRP he said they use a DPDT (double pole double throw) switch with a neutral ground.
I could use some input on whether the Dodge switch will work or not.
First diagram is the wiring of a common DPDT switch, just for reference.
The second is the wiring diagram between the TIPM(totally integrated power module) to the pedal adjust switch to the pedal adjust motor from the Dodge service manual.
On the Dodge switch connector shown in the wiring diagram the connector pin-out functions are labeled
Pin 1: adjustable pedals motor rearward
Pin 2: adjustable pedals output
Pin 3: blank (no wire or pin)
Pin 4: ground
Pin 5: Fused ignition switch output (run)
Pin 6: Adjustable pedals motor forward
There is that symbol below pin 5, I believe it indicates a led (light emitting diode) but not certain.
Any thoughts, I would really hate to hook up the dodge switch and burn out the cutout motor.
Pin 4: ground
