Just installed a Cummins E-Brake on my truck. I was very pleased with the kit & it went on exactly as advertised. I have one question - the directions call for connecting the switch power for the brake to the auxiliary power port (cigarette lighter). This supplys continuous power - therefore, the switch if left on, will always be on burning an indicator light even if the truck is left idle for a few days. Seems to me it would be smarter to connecct this switch to switched power so the switch would go off with the ignition and come on with the ignitiion if the switch is left in the on position.
2 Questions
Why would Cummins recommend the switch be powered at all times?
Does anyone know of an easy source of switched power under the dash. I don't think this light creates any significant load. I believe the power to actuate the brake itself comes from the ECM. At least the ECM wire is the one with the fuse in it.
Thanks in advance for your help.
'01 Black extended cab 4X4 SLT+ 6 spd. Westin grille guard, nerf bars and bed rails. ISO Pro guages, Line-X bed liner, Westin kick out steps.
2 Questions
