Originally posted by Big White Beast
Are you saying you'd want to pull the axle tubes off the pumpkin on the rears?? That would be the only way to get the end brackets for the backing plates the same. Then there would be alignment issues getting them straight & true.
Labor wise your best bet is to just swap gears. If your unfamiliar with the process I would have a reputable shop do it. They should be able to do the swap on both trucks in a day. Cost wise I have no idea.
EDIT: Fronts should be a Dana 70 & rears a Dana 80 on the 3500's. Not positive on the fronts, may be a 60.
Garrett
