Syclone Electromagnetic Clutch fan
Brush guard for the right person in NE
Moulding Vendor
Saw this advertisement @ U. S Gear. Similar to a Horton... but 1/2 the cost. Presently not made for a B-Series Cummins Engine.
see here: http://www.usgear.com/cyclone.htm
I e-mailed them about the availability of a clutch for a Cummins B Series:
Thanks for your inquiry regarding the availability of the Syclone style Fan Clutch for the I6B 5. 9L Turbo Diesel
Dodge Pickup trucks.
At the present time, we are actively working toward completing the launch of the Syclone fan drive system for the
1999 and later P********* Diesel equipped F*** Super Duty Pickups. As we get that product into the A/M stream,
our next task will be to evaluate and make the necessary changes to be able to expand our product offerings in the
area of the 94 thru 97 F*** P******** Diesel pickups, as well as the I6B 5. 9 L Cummins powered Dodge pickups.
Our initial investigations indicate that Cummins/Dodge have changed the direction of rotation of the Water pump/Fan
drive on the new 24 Valve/Electronically controlled Diesel engines. Additionally, there is not a lot of room between
the front of the Water pump/Fan drive mounting spud, and the rear of the radiator core. Not to fear, we have the same
problem on the 94 thru 97 F*** P******** diesels!! We believe that we will have a product design which will service
these two applications, but the biggest obstacle will be finding a plastic fan which can be adapted to serve them both.
The cost to tool a new plastic fan will be in the neighborhood of $90,000, and we need to find a partner who will be willing
to share those expenses. The fans presently used on both the Dodge and the older F***'s are both of steel construction. They are both different enough, that neither could be used for both applications. We believe we may have a solution for
this problem, but it will take us sum time to work out the details.
Additionally, our investigations indicate that the Horton Fan Clutches presently available through Mopar Parts will
only fit the old style, non-electronically controlled, 12 valve versions of the I6B 5. 9 L Cummins engines. The Water
Pump/Fan drives on those engines turns in the opposite direction, so the Plastic Fan blade provided in the Horton
kit will not fit or work on the newer version of the I6 B 5. 9L 24V Turbo diesels.
Bill, we will keep you posted on our developments in the future as we address these issues. Again, thanks for your
interest in this exciting new product application.
Best Regards,
Ron Fenelon
Note: Ron`s email was edited by yours truly #ad
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 03-07-2000). ]
Correct me if I'm wrong, but the Horton has its own electric motor and stands alone from the engine, while this unit would simply replace the stock fan and clutch assembly, resulting in a lower load than the stock assembly, but not as low as the Horton. Not trying to incite violence, just trying to compare the two units. Both would be an improvement over the stock fan/clutch.
Tim Barlow
So Ron thinks the fan is driven off of the water pump on the Cummins? I'll stay with the viscous clutch. It only draws about 9 hawspower so says the TDR rag and I'll have to assume that's in it's engaged state. During it's disengaged state, it's only turning about 15% of engine speed and isn't likely to draw enough hp to worry about. Be warry of something that costs half as much and is represented by someone who thinks the fan is driven off of the water pump on the Cummins.
The Horton is the real thing if you must. It's an electromagnetic clutch that is either 100% on or off. It's not an electric motor that drives the fan. The fan is still driven by the big Cummins.
Steve McDaniel,
98 2500 CC 4X2 12v 5spd 4. 10, Comanche 245/75R16Es, Monroe LT Plus shocks, Silencer ring removed, Stainless exhaust flex coupling.
97 Dodge Stratus 150HP
92 Harley Fatboy, Dynojet fuel management, Supertrapp 2-1
The waterpump/fan statement by Ron is probably just a typo. They havent really started designing the fan for the Cummins engine yet. Hey... . Ron answered my e-mail in a day. And they don`t even manufacture the fan for our application yet. He took the time to respond to my concerns. My hats off to him. Lots of companies never reply to Electronic mail. Especially if they don`t make a part for your application, and if they know that you ain`t gonna buy anything #ad
Bill R
I have to come to Ron's defense here. In the service manual for my 98 24 valve, it states the following. "The thermal viscous fan drive is a silicone-fluid filled coupling used to CONNECT THE FAN BLADES TO THE WATER PUMP SHAFT".
I do not know the source of Ron's information, and I know nothing of Ron or his company, but I would hesitate to flame on him and dismiss him as some kind of idiot at this early stage of the game. He may very well have read the same paragraph I just quoted. At least he took the time to reply to the inquiry, and I will certainly look into his product, as I believe that as good as the Horton is, it is obscenely overpriced.
