You guys that have been through it what are some of the early signs?I've pulled some old 252 and 253 codes out with my scanner,which someone told me was fuel pump solenoid codes. I am also having problems with my Comp not producing in levels 4 or 5x5. If I turn it back to 3 it seems to make power and smoke,but if I switch it to 4 or 5 it seems like it trys to shift but doesn't. This is a brand new Comp as the old one went tango uniform. It seems like it has gradually lost power and my e. t. s were off a little in the spring. I'm going to check all the wiring on the Comp and engine before I do anything,just wanting some advice before I shell out $1400
. Also will a HO pump work on a SO engine??? Any gains???Any help appreciated... Doug
