fifth gear
not knowing the date of Nv's modification of the main shaft, --they cut a keyway down the lenght of same,--and the use of the " long- nose'd" thicker /more threads (castle styled nut w/o the slots) they then staked the nut into the keyway... ... . now say you bought this rig new(you know no one has been in there) ---AND the sound comming from the shifter lever sounds like it is full of B B's that could be the case... ... Depending on your build date.
How do i know this,my 96 failed at 36 k aprox a month and a half out of the box. 1k from the house ,got it up and apart (rented shop hoist and a owners employee) reused old nut and 5th gear-red loc tite-cranked it down some where around 300 guess/ chin up on breaker bar with pipe over handle!!
The last touch was to use a 3 lb hammer and a 3/16 center punch and stake'ed about 5 times . it was just to get home. . stayed on the shaft for 168k but the B B sound started about 15 k before failure. i but a light shirt on the sifter to kill the noise knowing it should wipe evere thread off the shaft $$$ and nut.
I have both in the shop the nut can be put on just by sliding it in place,the shaft threads look to be un harmed. .
I talked to NV (how i found out the the key shaft repair) and got a the to be released split nut to test in the real world,and heart about the extended spline theory.
The test of the split nut failed,aprox 50k 70% under tow. reported the results, Installed the superceeded split which is nv part # 1875 - loc tite-and a big hammer and center punch-aprox ten stakes with deadly blows and it is still secrue over 400 k later do you need an extended shaft or new 5 th gear?????
I didnt??????? Oh also told STD how i kept the first nut in place,back in early 97 and if you read the tdr issue what do they do to the nut after tighting it down?????
MOST important If the B B noise is "NOT " gone in 1 thru 4 th something else is the cause. . What i'd have to rack my brain because with out abuse(speed shifts--dumping massive torque under heavy weight/hi rpm) I chang the lube every 100k (not on d/c list but the same mfg,oem bearings and sync's an clutches in place.
I did install one option--3' mag to pto cover to attract anything that might float around. always been clean. . Good luck!!
