Alan Reagan
I finally had enough of the POS Ram drag link and ordered the Synergy one. My link was welded half way around on each nut. I suddenly developed a steering problem where I was having to steer to the right going down the road. The alignment shop I’ve always used was hesitant to cut the welds if they did an alignment due to it being done as a recall.
Turns out I have a bad tie rod on the left side. I had already ordered the drag link so I turned around and ordered the tie rod as well. I installed the drag link today. The .5 hour recommended install time obviously doesn’t include the two hours it takes to remove the pitman arm tie rod. I didn’t want to beat it out and the tie rod puller wasn’t getting the job done. Finally, I sprayed the tie rod taper with Deep Creep, tightened up the puller and went inside to warm up. When I went back to the shop, the tie rod had popped out.
The Synergy drag link is stout. The tie rods have zerks. Everything fit like it was supposed to. Had to only make a half turn adjustment on adjuster bolt to straighten the wheel so the instructions on setup before installation were very good. The Synergy tie rod will be here later this week and I expect it to be easier to install (if the tie rods will pop out of the knuckle). I will do a shop alignment check and take it to an alignment shop if necessary. I just have to decide if I want something less than 1/8 toe in. This setup should last the life of my stock truck. At least it’s serviceable.
