I know there is a break in period before switching to a synthetic oil. Is there a cut off point after so many miles that you can't switch to synthetic? I currently have 232k on my truck, is it a bad idea to switch now? Currently just looking at all options and ideas to maybe lower some cost and not change the oil so often.
There are some things to consider when changeing to a Synthetic oil after the use of petroliem oils.
1-If the oil has been changed at timely intervals, there most likely is not much build-up of sludge and varnish in and around the engine seals. If the oil change interval have been neglected, then there is most liely going to be build-up of sludge and varnish, which will then be
"cleaned out, by the synthetic oil, as a true synthetic, such as Amsoil, is highly detergent! This in turn will allow some leakage thru the seals, as they were most likely sealed up by the sludge and varnish build-up. The best way to test this is to pul off the valve cover, and see what kind of sludge you may have.
2-If the engine has a lot of wear in the area of rings, valve stems, or valve guides, then you will most likely use the oil regardless.
3- If your engine is already useing some oil between 5-7,000 miles, it is mot lkely not a very good candidate for Synthetics, as most synthetics do have better detergancy, although some are not much different than a regular petroliem product.
In my experiences, I have seen some high mileage Engines do very well switching over, but I have also seen some that didn't do so well.
The only real way for you to know is to try it for awhile, then you will know for sure.
