Was gonna dump the oil on my 2015 at 5000 miles just to get the break in particulates out.you guys recommend synthetic or rottella t 15/40.had 3 different 5.9,s always ran rottella or Mobil delvac no problems .
I'm curious why the factory uses sythetic? is there a reason? Most of the time only vehicles that "need" it will come that way from the factory. I also find it curious when I brought my '15 into the dealer they "tried" to put conventional oil in. I found out before it was done and told them I wanted "exactly what it came with".
IMHO yes DO run synthetic but run 15/40 since you are not in sub freezing conditions all the time.
I run the 100% Synthetic AMZ/OIL 15/40. Did in the 11 HO also and had great Blackstone test results at 7-7,500 miles.
I ran 15/40 Rotella in my 2nd gen for the 13 years I had it. I never did run a Blackstone test though, despite getting a bottle years ago. I figured on my '15 I'd just stick with the factory fill until I get about 10k miles or so on it. Amazingly I'm about to turn 9k on it already.
extended intervals don't work well with the aftertreatment trucks due to fuel contamination.Is synthetic needed to meet standard oil change intervals? no says Cummins.That is good enough for me.I do not see oiling failures on the Cummins.If it lets you sleep better go for it.
Its the extend intervals that the Synthetic producers promote, I stand With Bob4x4, Good gosch Ams thinks theirs product are equal to pouring gold.OK its good oil but its twice the price of others. Shop around you can buy Quality Syn oils for fair prices, run it 10K and drop it...Hmm look at FCA spec for 3.0 oil $60.00 PG...AutoZone had Pennzoil Ultimate for $28 P5L with $15 RB, What.... the last time I check the 6.7 & 3.0 all had internal parts that need lubrication NO different then 10s of million of engines. If My 6.7s or 3.0s or any engines I own use oil there gone or Re-done.
If you dump your oil every 5-7K use STD oil, if you run 10-15K use syn oil. Now if you live in cold or extreme cold or heat use syn oils, But whatever you decide change it regularly.
