If you have the patience read this. Seems like Mobil 1(or it's new equivalent) is the one to use $4 /qt though,I'll keep using Delo. I think MGM's on vacation, that's why no one is jumping in for Amsoil.
I'd never try to replace MGM in this discussion, but perhaps I can entertain the audience until his return...
First, for any newbies, NEVER use Mobil 1 - it is not rated for the Cummins diesel. But you can use it's kissin' cousin, Mobil Delvac 1 (the "diesel" version of Mobil 1). The thread on noria.com was discussing Amsoil vs. Mobil 1 in gasoline engine applications - much of what was said does not apply to our diesel application, although some of the discussions about marketing hype are worthy of careful consideration. The Delvac 1 will probably run $5 to $6 per quart.
I figure I'm spending less than $0. 01 per mile on synthetic oil, and that includes filters, analysis, etc. Yep, I could probably cut costs by going to regular oil, but, I'm more comfortable with cold starts and more comfortable with hot shutdowns (turbo) using synthetic. For me, that comfort is worth $0. 01 added to the other costs of ownership; some others feel differently, and I'm OK with that, too.
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
