SYNTHETIC POWER STEERING FLUID
Texas Limo
Where is the fuse???
MY 95 IS HARD TO STEER. DO THEY MAKE 100% SYNTHETIC POWER STEERING FLIUD (NOT A BLEND)?
CAN YOU USE A AUTOMATIC TRANS FLUID? OR WILL A BLEND WORK OK? THANKS FOR THE HELP LINE TDR!!!!
I believe the Valvoline stuff you can get is 100%.
It's in a silver plastic container.
I got mine at Pep boys. It costs about $3. 50 per quart.
HTH Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Royal Purple MaxEZ Power Steering Fluid is a synthetic.
Shouldn't make that much of a difference if you're in NC though as your signiture indicates. Not cold enough to cause the power steering to be overly sluggest. (I grew up in Wisconsin so know cold weather).
You might want to check to make sure you have proper operation of the whole steering system, ie grease the zerk fittings, etc.
Good luck
I was looking for the Valvoline and all I could find at Pep Boys and Walmart was a blend. Is this what everyone is talking about. If not, where can I get The Royal Purple from? BTW Walmart was under $3 a bottle.
'01 2500 4x4 4. 10 White/Driftwood QC plain SLT auto trans snow prep camper package tow package bed liner mopar mud flaps Reading Ind. 33" tall contractors cap. Toys: 3 mountain bikes, a cyclo-cross bike, and a road bike, plus a couple of whitewater kayaks. Yeah, I know their human powered, but the bikes are fun to modify too. Like spending $$$ to make trucks more powerful, It takes $$ to make bikes lighter. Titanium isn't cheap.
