Just a possible option... Instead of adding another bulk head fitting to the fuel canister / module (or directly onto the tank) for the AD 100 / FASS 95 return line, what about installing a "T" fitting into the existing stock fuel return line instead?
Looking at some of the "modified fuel canister" pictures (unless the tube was removed), it looks like the stock return connection just drops / sprays into the fuel canister (vs. a tube to return the fuel to the bottom of the canister).
I also thought about using the ‘auxiliary fitting’, but then I would need some sort of 90* compression fitting on that plastic stub vs. directly connecting the return line but with time it would bend and cause a kink in the fuel return line.
Pro's / Con's to the stock fuel return line ‘T’ approach?
