Engine/Transmission (1994 - 1998) t/c lockup
2nd Gen Non-Engine/Transmission Block heater wattage?
2nd Gen Non-Engine/Transmission 94 to 2001 steel wheels
i've had my dtt installed for about a month now, and the only problem i have with it is the tc will only lock up on very light throttle, anything more than light throttle it will not lock up unless i let off, then it will stay locked until i push on the brake or slow down enough for it to unlock on its own.
would this be the tps voltage too high or ?
thanks, corey
Who was your installer ? I cannot tell from your profile what state you are in . At any rate if you want a hand give us a call at head office. Give us the state you are in and your name and we will pull your truck file and give you a hand .
I was planning on calling anyway, I just thought I would put this out there so maybe other people could benefit from the solution.
