Here we go with transmission concerns. I thought I had a l-up clutch problem while using "The Box". Anyway, about 2 weeks ago, T/C starting l-up fine, no slipping, even on max boost and fueling (empty). Added the slide-in and boat behind, still no problem.
The issue is, it appears to slightly jerk while in l-up. I can't see the Tach move, but it is slight, and it gets annoying. What I did 2 months ago to attempt to curb my unknown problem, was put a slight push on the A/V cable, to increase shift points and line pressure.
2 problems, don't know why it works fine again, second, should I re-adjust A/V cable, as I really like it shifting just a bit later(200-400 rpm)
