Is it possible to splice the vacuum line that controls the transfer case? After removing my transmission I noticed that two of the lines had been cut some how. They are two that come from the firewall area over the trans (green/white?) and then the harness intercepts with and zip ties on the two (red/white?) that come from the metal lines on the crossmember, then they go to that rubber 4-hole plug that goes on top of the transfer case. Could those two be spliced some how, or is there a temporary fix, or is this a good time to install a 2-Low kit (not sure which lines are cut with that installation. I'm held up for now until Monday or Tuesday waiting for a rear output seal on the t-case, but would appreciate some guidance or assistance with this.
Thanks
Thanks
