Archived T- steering conversion Help!
Archived Very rough idle
Archived hard starting 2003 Cummins Ram
any of you guys that have done the T conversion, maybe you could help.
First. Install was going smooth until I got to the pitman arm. the taper on the stock pitman arm is different from the end that goes into it. anyone have a similar problem? also would I need to get a newer year pitman arm? will the steering box end be the same? Or is it as simple as a differnt tie rod end?
someone please help
thanks in advance
Mike
