Just passing along some feedback on my recent Crank Position Sensor change. Symptoms included a eratic loss of tach, check engine light, and limitation of power. Otherwise, truck ran normal.
So I read several threads and purchased the sensor from a local dealer ($64 - not bad). Starter needs to be removed - no problem with this step. Sensor is located inbetween the starter and the block - it's the only thing there. Then it started !
Sensor twisted/turned but would not pull out. It broke into smaller pieces which eventually led to the sensor being flush with the block. I drilled - and drilled - and drilled. Tapped the plastic and it broke away into smaller pieces. I'll cut to the chase - 6 hours !
My recommendations. Break the sensor out of the block into enough small pieces that you can pry out the rubber O-ring. With a hole drilled in the sensor, it actually prys out of the block.
Reinstallation was less than 15-minutes !
I'd still do the job again now that I know the pain.
