tach hookup?
More Tach Questions/ Gtech
Valve cover Gaskets
One type that will work is one driven by alternator pulses. That's what I have. You'll need to remove the rear cover and attach a lead to one of the rectifiers.
Another type is one that requires a sensor to be attached (glued) to the outside of the alternator.
Another requires a sensor to be attached and read the harmonic balancer.
So there are a few choices. They all work.
Hope this helps.
Jay
I just got done connecting my tach to the alternator this last weekend.
Works great and only cost was 5 feet of wire.
If you get the pickup for the harmonic balancer, it will be around 70 dollars.
In either case you will need a tach that will read the pulses per engine revolution.
I got the sensor for the h-balancer for around $40 shipped to me a few years ago. Had magnets to glue onto the h-balancer for the sender to read. Worked just fine, and I still ahve the sensor and wiring.
Dnaiel
