Engine/Transmission (1994 - 1998) Tach issues!! (Aftermarket and stock)
2nd Gen Non-Engine/Transmission napa steering box
Engine/Transmission (1998.5 - 2002) LED Taillights on 01 2500
I just purchased a Fluid damper and a 5" Autometer tach,
the autometer tach requires 4 signals from the damper but the stock damper uses 2.
Before thinking it through I machined two more grooves in the damper for the autometer tach.
So now what will happen with the stock tach if i use that damper with the 4 grooves??? (signals)
:confused: :confused: :confused:
Michael
JerrodGlover said:
On a related note, anyone know what wires are what on the factory sensor?
do you mean on the back of the gauge cluster??
Im going to look in a couple of days and disconnect mine because i think (like wildman said) i might be doing double
Michael
Highfinance:
Why not just step the grooves on the damper? If its wide enough for that, I dunno if it is... you could run the stock closer to the engine, and leave the 2 original grooves there, and just put two more at the far side of the damper... ?
hey, i could be way off base... who knows.
-j
tp0d said:
Highfinance:
-j
wish i thought of that before i machined the damper :-laf
Michael
tp0d said:
Highfinance:
-j
I did it, i steped the grooves and it worked out awesome
Michael
