I have a recently (ok, not THAT recently- back in late January) acqired 92 D350 that I'd like to hook up one of my ISSPRO tachs into. Problem is, I hook it up and start the engine. I'll have 350-400rpm for 3-4sec, then it drops dead. Air gap on crank sensor is set to . 048-. 049" per directions in this very forum. I tried jumping the input and tach output wires (43 & 24) like one person here did recently, to no avail. He had good luck.
Could I need a new crank sensor? (cruise is inop; voltage reading is sporadic- 12. 5-13. 5; but it IS a factory gague) Or am I missing something painfully simple? Guess I could hook a voltmeter up to the wire under the dash, and see if the output is smooth as RPM increases. I would use the setup from the 91 (no plug in on it), but I am missing the magnets, cause I forgot to take them out of the old truck when it sold. but I'd like to just plug it in and go. Chris (dieselman359) said he had similar troubles when he plugged in teh tach on his 93, and fixed it with the install kit from ISSPRO; others ahve said it is a waste of money.
Daniel
Daniel
