Tach wire
700 miles on one tank yesterday......
Trans Service
I picked up a Stewart Warner Tach light at the charity pull last night. Does anyone know where the tach wire is? What color, any help would be greatful. Thanks. :)
I'm not sure you can use a tach light on a diesel (unless it's specially designed). Remember, there is no ignition system on a diesel. The ECM computes the engine RPM from the crank position sensor mounted beneath the crank pulley. It's a magnetic pickup.
There is no tach wire going to the instrument panel: it's a PCI bus. Basically, that means there's 1 wire that provides communication from the Front Control Module to the instrument cluster, where the signal is de-multiplexed and decoded to derive the various signals for the instruments.
Think of it sort of like the ethernet connection on your computer... there's no one single wire for "TDR". ;)
