jerry,
i just last weekend put an Isspro 4k rpm tach in my 93' W250. I bought it from
USDieselParts.Com. they make a wiring kit for the 92-and up dodge cummins. the tach was a little over $100, wiring kit was bout $40. Very easy! just wire the tach to the wireing kit if you order it, and plug it in.
just so you know tho, the wiring kit they have available for the 92-up, cummins, has 4 wires wich you wire into the tach, and 5 wires, 4 of wich wire into the harness under the dash. there is a white and a yellow that come from the wiring kit end, they are interchangable for 2 different tachs. my intructions told me to use the white. i did. the tach fluttered real bad and would not give a reading untill 1500rpms. i called Isspro, the tech support told be to switch the white to yellow, and disregard the instructions, becuase it may have been done backward in the assyble of the kit. i did it, and its worked flawlessly.
just tell him to order a mount for it, unless he is really creative. i didnt order a mount... so my $160 tachometer setup is sitting very nicely in a high dollar Cheerwine soda can.
hope this helps, if you want the part numbers for the tach and kit, ill give em to ya.
