As per 96 factory service manual.
The tach module in the instrument cluster operates the tach.
The powertrain control module (pcm) supplies the signal for the tach on circuit G21. Circuit G21 connects to cavity C31 of the PCM.
G21 is grey/light blue wire.(runs fron tach to pcm).
Engine speed sensor = 5 volt supply violet/white, crank position sensor signal (ess)grey/black, sensor ground black/light blue.
Engine speed sensor connections to PCM, ground a4,signal a8, power a17.
Hope this helps.
