moparmikeJ
I have a foam board blocking most of the radiator, and drive 15 miles to work. The truck isn't up to temp and I'm at work already. Normal? Or is my thermostat stuck open?
Mike
Mike
Block heater works! WTS light goes out within seconds.
When I arrive at work, temp is a little over the 165 line on the gauge. (2nd line up from stone cold)
Have had the truck since '05, my route is rural, and it drops in elevation pretty much the whole way. Going home, it warms up decently. (Uphill) I've been plugging it in every night.
Mike
Ah, yes. Outside temps have been between 20 and 35 or so.I will be more clear. What are the outside temps?
Did one of you read that he said he is idling downhill the whole ride?
I didn't. I read " 15 miles to work" and "my route is rural, and it drops in elevation pretty much the whole way."
