taking off the ez
Looking for recomendation on a shop to install gauges
Wiring Question
If the edge product ez is taken off but the boost elbow is left on will boost of some type of error code show up. . ?
Thanks
Ken
1998 1/2 24 valve 2500 automatic 3. 55 alcoa aluminum wheels
Rhino Liner.
YES. If the boost elbow is left on then boost will increase past the dodge ECM's limit of 21 PSI and it will make a check engine light appear and your truck will not get as much fuel. It is not a good idea to do this.
FYI- leave the two map connections hooked up and unplug the triangle connector in front, this will keep the error code and defueling from happening.
·1999 2500 QC LB Auto 3. 55 4x4
·Armorthane Bed liner, A-pillar gauges, RE-0880, EZ, 275's, Husky mats, strait pipe
