For almost a year my truck has been taking spells of running rough. at first it was hardly noticeable. It only happened a couple of times going down the interstate(just a slight change in the way it sounded and slight cutting out just momentarily). I dismissed it as bad fuel and needed a filter change. since then it has increased more and more. now it's not reliable enough to drive it out of town. It could just be a minor miss or it could die completely or any where in between. It could go a month or a day and run just fine. If its a bad spell going down the highway it will rev like the throttle is stuck and then die. It always starts back up immediately even if i have to give it a little pedal until it can idle on its own. when it is cutting out there is a slight ticking noise under the hood. It is usually brought on under load like running out of fuel, but once it cuts out once it will only get worse the rest of the day even with no load. after it sits all night it is fine the next day. I have read similar stories on here and have researched it. I've changed the fuel filter and drained it to see if theres water when it cuts out and there is none. I have changed the prefilter screen. I've looked at all the fuel lines, but haven't replaced any cause they look fine to me. I put a new tank on 6 months ago so i know the problem isn't there it was acting up before the tank. I don't have any fuel leaks but could have an air leak that i don't know about. have also replaced fuel solenoid with cable so thats not it. My thoughts now are to mount a fuel pressure gauge so i can monitor the pressure during a spell to see whats going on. If it has pressure during the spell then it must be the injector (right?). does it sound like air? Any ideas or similar stories would be appreciated. thanks.
