Hi out there,
For those of you who have tapped your exhaust manifold,well I just completed mine. I used the 5/16 drill and 1/8 n. p. t. I found it hard to start the tap as it seemed like it wanted to wallow out the hole. I finally got it started and it seemed like i had to tap almost the length of the tap to get treads good enough to start the probe nipple. The nipple screwed in o. k. and I was careful to make sure it was flush with the inside of the manifold. I used never sieze and it seems like the probe nipple is still a little loose. It cant turn out of there after the probe is installed. Just wondering if it will tighten up as the manifold gets hot. I guess I will have to keep an eye on it for a while. Did this ever happen to anyone else ?
Thanks
Al
Thanks
Al
