I was wondering if someone could explain what exactly does tapping the pump wire do to the pump? I know it signals for more fuel, but is that tap sending more voltage. . or??
Reason I asked is I installed the TST PowerMax I bought like 5 months ago today.
Also I had to tap another pump wire (black with brown chaser I believe) in the maine wiring harness that's on the pump. Anyone know what that wire does?
Also the setup uses scotchloks. I hate those things, so I cut the pump wire and used a butt connector. Well it proved to be a PITA to re-connect the other end of the pump wire cause there's not much room to work with, so I added another 3" or so of same gauge wire to make things easier to work with. I taped it all up and put wire loom on it. Not exactly my pride and joy, but I couldn't think of a better way of doing it after I had cut the wire. I'm sure someone is laughing at me right now
I was thinking... this wire doesn't need to be a special length or anything... right? (I hope). Truck seems to run fine and all.
