The big rectangular gasket on the drivers side of the block... . I hate it!!!
There appears to be a noise deading pad over the cover held on by nuts to a few studs. Then the cover/gasket itself held on by the 10 mm bolts.
It appears that I will have to remove the LIFT PUMP to get this thing off????
Geeez, its a nightmare.
So in addition to the cam follower gasket, I'll also need a lift pump gasket, and have to deal with even more fuel lines???
Anything else I should move out of the way now??
Thanks,
Brian
Thanks,
Brian
