Tappet Cover and
2nd gen 12 valve digital gauge options?
Fuel leaking from left side of engine
Iron Duke II
The tappet cover on the '96 12V started leaking at sustained pressure during a test drive towing our small Nomad 5th wheel trailer. Lost about a quart on the 84 mile round trip. The leak appears to be coming from above the vacuum pump.
If it is the tappet gasket, is there a preferred brand of gasket that is an improvement over the OEM Cummins version?
This is another option albeit a pricier option but these tappet covers employ an o-ring seal and look pretty nice to boot. They are out of stock at the moment but hopefully will have more soon. I put one of these on the wife's truck when I had Bosch 275 RV injectors installed and the cylinder head & gasket rebuild done.
https://bdpshop.com/bean-machine-89-02-cummins-billet-tappet-cover-temporarily-out-of-stock/
Power Driven Diesel has a similar billet cover but does not use a true o-ring but I think it would seal much better than the OEM stuff.
https://powerdrivendiesel.com/product/pdd-billet-tappet-cover/
Did you read the other threads? There were several other suggestions and advice.
Personally, I’ve had success using the yellow 3M Weatherstip Adhesive to “glue” the gasket to the cover, let it sit overnight, then install the cover dry.
Sorry folks. I am experiencing medical issues and was unable to get to this myself. So the truck was taken into the shop that has performed some maintenance for us over the years. It appears after further investigation the leak was coming for a loose bolt on the rear of the p-pump. The fix cost $90, labor only. Thanks
