Just rebuilt the motor and started it up today and everything looked good. Then I looked under the truck after a couple of minutes and had oil all over the ground. Looks like the tappet cover is leaking. It feels like the gasket has pushed out a little at several places where the block has a dip. Is there a certain way to put the gasket on thats best? I originally torqued the bolts to 20lbs. Also has anyone ever replaced the gasket with the pump on? Help is need quickly. Thanks
