I have just spent 8 hours cleaning engine and trying to stop tappet cover leak, it appears that the gasket has cracked and has just started gushing oil. I see that I am going to have to bite the bullet and pull the p7100 pump and virtually all the rest of the drivers side engine accessories. I have not pulled the pump before and I am a bit intimidated by the project. I have searched the forums but need some advice;
1/ Where to buy puller for pump gear. ( I hope I do not have to remove timing gear cover, KDP done 2 years ago).
2/ Is there a key on the pump gear? some posts I read indicate that the gear is on a taper, I do not want to loose the key in the gear case.
3/ Do I need barring tool to hold engine whilst re-torquing pump gear bolt?
4/ If I pin engine at TDC and pin pump timing, do I have to invest in timing kit or could I get timing re-set just by marking components.
5/ any other advice?
Thanks,
Nigel. 1996 2500 2wd. Auto trans. 400K ml. Riverside CA.
Thanks,
