Hello all,
I've got a 2003 H. O. Cummins in a Hummer H1 and want to mount the EGT probe. Unfortunately there isn't room access to drill and tap a hole in the exhaust manifold right above the turbo. Even with a small right hand drill, I can't get to it. I would need to pull the exhaust manifold off.
I do have access to the 45 degree cast peice directly behind the Holset turbo. The probe would be about 2" behind the turbo. Is this a suitable location and can the cast metal be drilled and tapped? It looks like cast iron and I've never tapped that material before. Also, since it's curved, is there any type of epoxy I can use in the event I need some.
