Hi,
I will be installing additional driving lights, and want to switch them to only come on with high beams. Normally I would tap into the highbeam wire at the back of one light, use this as one leg of the coil circuit in the spotlight relay, and run the other leg of that circuit to earth through a switch in the cabin.
I have seen a thread on here saying this was still the right way to go for an older model (2007 I think). Has anyone done it this way on a '14, and did you get any error messages from the computer? Is there an easy way/place to pick up the headlight feed, other than the dreaded scotchclips?
Oddly, I can't spot this in the Body Builder's guide. Am I missing it there?
Thanks,
Matt
Thanks,
Matt
