2nd Gen Non-Engine/Transmission Tapping into heated seat w/alarm aux wire
2nd Gen Non-Engine/Transmission Behind dash pics on '97?
Hey guys, I just searched many posts looking for the right wire to tap into the heated seats for my alarm install. No luck yet, although Ive seen it posted a few years back. Doing the autostart thing . Should I tap behind the switch or ? Thanks in advance--Proflow
__________________
02' x-tra cab 4x4, 410's,DTT auto, mad ecu, hot comp box, dd111's, bhaf filter, 4" exhaust w/5" stacks, Dakota Digital gauges, & then some
thats what I would do. just test the wire before and after you push the button to make sure the alarm sends the right signal to it.
is your alarm programmable so that aux wire automatically comes on when you remote start it or are you going to have to hit different buttons along with the remote start? if thats the case you may be better off running another relay off your accessory so it comes on by itself. just make it easy to get to so you can bypass it come summertime.
heated seats
The alarm has an aux. wire that'll momentary or constant power that acts when auto start is used. Obviously Id yust momentary just as if I pushed it w/my finger. Not sure if Dodge has a neg. trip on this like the headlights or what though. They did some weird things here & there. Thanks--Proflow
