Engine/Transmission (1998.5 - 2002) tapping pump wire?
for the edge drag comp if u do not tap the pump wire is it true that it only puts out the power of an ez no matter what level it is on?
Yes, but you can adjust it to the 5 sub levels.
jaybigboy34 said:
My question is, if you don't tap the pump wire and it runs like an EZ, can you turn the power level down to run less than an EZ?
Yes, just turn it off. You can still run extra boost, as it boost fooler circuit is still in effect.
Set it up like this:
1x1
2x2
3x3
4x4
5x5
Now as you select main levels you vary the sublevel. I drive around on 3x3 without a pump wire most of the time. In the snow I turn it off if I want to detune a bit. SNOKING
