What exactly is tapping the pump wire? From what I understand, adding any box is tepping the wire, but I wanted to clearify some things. I have heard that some pumps don't mind it and some will die in a matter of minutes. What does tapping it do? Is there a way to tell if the pump is good or bad? I read this on the Edge Website about their comp box:
Power Level 1 on the Comp is the same as the EZ; on Power Levels 2-5 additional power is added via the wire tap onto the injection pump. If the pump wire is not attached with a Comp, Levels 2-5 are still operational, but the power gain is not any higher than Level 1. Under this scenario, however, power will come on much earlier in the throttle.
What do they mean by attaching the pump wire? Is attaching the pump wire considered tapping it?
Thanks
Thanks
