TDC Pin Part# or Dimensions
used turbos
Clutch recommendations?
I really need some help here. I am looking for the Part# for the TDC pin which is needed to find and hold TDC during pump removal. If anyone has a service manual from model year 89 to 98 the part# is listed in there. If anyone has this pin and could measure it and give me the dimensions I can make it.
Thanks,
Jeff
I couldn't copy and paste a picture, but here are the 3 P/Ns' for all the pieces to go in the timing pin housing, the housing, and seal between housing and gear cover.
3903924 Pin, Timing
3904849 Ring, Retaining
3913994 Seal, O Ring
3919683 Housing, Timing Pin
3915772 Seal, Rectangular Ring (goes between housing and gear cover if you take the housing off)
A Johnson
